DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
Kawasaki kc 100 starting problem
Old 12-29-2012 | 08:05 PM
gfullerkc100's Avatar
Red face Kawasaki kc 100 starting problem
hi all so a couple of week ago I came across a kc 100 in need of slight tlc at a bargin price so I snapped it up and let the fun begin here is my main problem I got it started tday as per and then it just stoped I av got a spark and its getting fuel I av already dun the ignition timing as this was wht was need in the tlc now the only think I can think of is if its over or under fueling as it came wth 2 carbs and I cleaned them both up but I am not sure wth size main jet is needed in this bike and they are both different size any info would be of a great help or hints or tips thanks
Old 12-29-2012 | 11:05 PM
Where are you located? Welcome to KF
Your manual should help you alittle on the mains, but you can also hit up your favorite fiche site for additional help.
Old 12-29-2012 | 11:54 PM
hi I am in barnsley I av looked in the manual and I carnt seem to find a main jet standered size. it strange cos it was running fine one min thn back fired a couple of time and stop running I av had the carb to bits to see if it the float chamber playing up as I had a little problem wth tht but it all seems ok and another thing is I dont say how to set the air flow I av always put them to 2 and a half turns out but am not sure if this is wright. for this bike
ready_2_retire@yahoo.com
08-11-2015 02:48 AM
kawasaki_1979_km100
01-29-2010 02:57 AM
truckermatt
05-05-2008 03:35 AM
pie4foou
02-01-2008 01:53 AM
Nighthound
09-04-2005 02:18 PM
Quick Reply: Kawasaki kc 100 starting problem
