DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
EX 500 3 inch drop
Old 07-05-2006 | 07:39 AM
c10's Avatar
c10
Default EX 500 3 inch drop
2006 ZZR 600 ( also the older model ZX6R ) dog bones can be used on a 1994 EX500 and up to drop the rear a total of 3" .
I can now leave the line at 8,000 rpms with one tooth down up front and two up in the back . I expect 60 foot times to be in
the 1.55 to 1.6 second range . She is fast out of the hole . I will probably get a mid 11 second in the 1/4 mile out of it .
My wife is short 5' 4 " with a 27 " inseam and she is now flat footed . I made my own risers allowing me to drop the front 1"
awhile back . I will post a pic tomorrow but the bike definitely looks mean low and Amber ( my wife ) loves it .
You must cut 1.5" off the side stand and weld a NEW FOOT on with the bike this low. Center stand can still be used but is MUCH more difficult to get up with the bike so low now . I DO RECOMEND it be removed .
Exhaust cans MUST have a 1" DENT OR RECESS done on the back side to clear the AXLE NUT as the supension moves up and down .
Also 1" of PLASTIC FENDER just above the SWING ARM by the shock must be trimmed of so it doesnt contact the arm as it moves up in travel .
Also the new links are aluminum and are half the weight of the STOCK STEEL MODELS . 10.4 ounces for the stock ones and 5.2 ounces
for the new ZZR model ones.
Old 07-05-2006 | 08:23 AM
BigRig18Wheeler's Avatar
Default RE: EX 500 3 inch drop
nice....Did you machine your own lowering links for the rear, or does someone make some?
3" is quite a bit...I bet she does look mean..Pics would be awesome man!!
Old 07-05-2006 | 10:10 PM
c10's Avatar
c10
these are STOCK zzr 600 links I used on the 500 . Pics later tonight
Old 08-09-2006 | 12:16 AM
Steve Ninja Strombol's Avatar
how would i go about raising my bike? at least the tail end? what parts or w/e would i need?
Old 08-09-2006 | 02:50 AM
c10's Avatar
c10
shorter than stock dog bones . Longer bones lower while shorther bone raise
disasterouskid14
KX125
07-20-2009 03:02 AM
Excidium28
10-20-2006 08:30 AM
charleshmosesii
08-12-2006 04:25 AM
Icantrideabike
07-01-2006 08:42 AM
Quick Reply: EX 500 3 inch drop
