adjusting shift light on a 05 636
Change the Shift Up Indicator Light
Mode to “OFF”:
The Shift-up indicator light can be used in
closed course competition. Do not use the
shift-up indicator during everyday riding.
The shift-up indicator light has three modes,
light off, light on (dim) and light on (bright).
•Change the light mode to “OFF” in the
tachometer.
•Turn the ignition key to “ON”.
•Push the MODE and RESET button simultaneously
for more than 2 seconds.
•To change the shift-up indicator light mode,
push the MODE button and the shift-up indicator
light will shift between light on (bright),
light on (dim), and off.
A. Shift Up Indicator Light
•To complete the adjustment, push the MODE
button and RESET button simultaneously for
more than two seconds.
Mode to “OFF”:
tachometer.
punkenduro09
12-08-2014 08:28 AM
