minor body damage
minor body damage
hey guys just bougt a 97 zx7 with only 5k miles on it, the guy i bought it from dropped it and did a little damage to some of the body work the upper has a small piece missing, and the lower left has some cracks in it where the directional must have got bent and damaged it, other than that the thing is in great condition, what would you reccomend using to fix that body damage, i dont want to buy new body pieces, i was thinkng of using the green bondo that has the fiberglass in it. has anyone had to do this in the past and what did you use????
RE: minor body damage
ive used that or the fiberglass resin and some sheets of fiberglass.... they both work good, and if its not that bad a crack, i would bondo the inside for reinforcement and then fill whatever needs on the out side. big thing is the sanding, if its got an even sand job, youll be good. good luck and congrats on a good find.
