zn 700 carb rebuild
installed rebuild kits into carbs. The carbs were pretty crappy with jets clogged etc. Installed back onto bike and started. Got it to fire up and settle into a reasonable idle. Warmed up with choke off and hit the throttle. Basically wants to die. I can catch it by turning on choke with no throttle and then open the choke and again settles into a decent idle. If you give it throttle it wants to die.
I do not have air cleaner boots on and have the air screws set to 1.5 turns out. Any ideas?
![Thumbs down](https://www.kawasakiforums.com/forum/images/icons/icon13.gif)
Dragone #19, I'm leaning toward pulling them off again and see if there is any crap in the carbs. Seemed when I dropped in the needle valves they didn't go in very easily. Would'nt the the other jets take over after I turn the throttle more than a 1/4 turn? It's almost like the gas is turned off when I give it some throttle. I did unclog the jets, maybe I still have a clog somewhere else
pfrancz
01-17-2015 12:56 PM
