z650 charging problem
Hola Folks,
I have a '78 z650 which had a regulator and a rectifier charging the battery. the rectifier burnt out so I have got a rectifier/regulator which is new.
The problem is now the battery is not charging. I have done all the tests for the stator and field coils and they both check out O.K.
The new rec/reg has 6 wires whereas the old system has 7 wires.
I have wired up like this:-
engine side reg/rec side
3 yellow wires 3 yellow wires
red/white red/white(to battery)
black black (to earth)
brown brown (to wiring curcuit for ign,lights etc
green wire(field coil) not connected
I think the green wire should have power from somewhere to activate the field coils. Does anyone know where this wire goes for defo as I am worried about damaging something.
I suspect when the field coils are activated, the charging process may start again.
I get about 12.5V at any revs with no variation.
Johntee
Johntee
Hola Dragone,
I think the green wire is to excite the stator and is on the switching circuit, according to the wiring diagram it goes back to the alternator, through a field coil and then to earth. Tonight I am going to measure the voltages on the wires, if there are any, with the engine running to see if the connections are right. If I still have no joy I'll try putting the green wire on the switching circuit and see what happens.
Put the green wire on the switched circuit and fired her up, 14v's across the battery at 4000revs. I'll go for a run tonight to make sure there are no problems and let you all know how I get on. Looking good so far though
I need help with a 1980 Z250. When I connect the rectifier to the wiring I can hear the coils being energise. If I leaf the connection on the battery goes dead. Is it a fair asumption that the rectifier is faulty? Where can I buy a replacement part?
