Need help! Turn signal issue
I have a 1981 KZ750H and I consider my self fairly mechanical. I swapped the motor harness and pretty much everything into a GPZ750 frame. So its a frankenstien bike, but runs beautifully.
My problem is that the right turn signal makes everything blinke, and by everything I mean gauges, break light, headlight, all the turn signals, and the volt meter jumps up and down when I put it on. The front turn signals are the originals off of the KZ and both left front and rear work flawlessly. But when I put on the right turn signal it is like someone is connecting and disconnecting the battery( everything blinks)
I have searched fourms for similar problems and havent found much. I cleaned all the connectors and the turnsignal switch. I changed the flasher fuses, both the 4-way and the turnsignal relay.
So I am lost and need help.
Thanks in advance
btw I am new to the fourm sorry for the long post
Thanks in advance
*Bump*
I am trying to get this solved. Any suggestions?
I forgot to add that the fronts are OEM signals off of the KZ and the backs I picked up online, but they are 12v 8watt signals nothing special. I know that LEDs and stuff like that have issues, but would the different lights be making the problem?
Thanks
Thanks
liberated
05-17-2012 07:36 PM
