Bike won't start
Bike won't start
Can anyone suggest anything?
I have a 1995 Vulcan 750 that I bought back in March. It ran without any problems until about 2 weeks ago. I would ride it at least 3 or 4 times a week until then. Now it will not start. It tries to turn over for about a half a second but then it seems to loose all power to it except the lights. It does this with each push of the starter button. I first thought that it was just a battery problem and when I checked it, it was dry, so I bought a new one and filled it and charged it and it is in great shape, but bike still will not start. I tried to jump the solenoid to see if that was the problem, but it just gave me the same reaction as pushing the starter button. It will start if I pop the clutch and it will run without any problems for as long as I want (tested for 1 hour ride), but when I turn it off, it will not start on its own no matter how long I wait.
If anyone can, any suggestions would be welcome.
Thanks in advance.
[&o]
Thanks in advance.
[&o]
RE: Bike won't start
Welcome to the forums....
Wow... Could be short in starter. Bad battery cable. Bad conncection.
I would say break out the multimeter. Check voltage, etc, at starter. While holding the voltmeter there, have someone hit the start button. Read what the voltage says until it loses power. Still have 12 volts? 9.6 volts? Lose all power at that point? Then trace backwards from there.
GL man
GL man
Found out what it was. there is a short between the starter switch and the starter. i accidentally found this out by hitting the starter button with my forks turned to the right. it will start every time I do that only. if i try it with the forks straight or to the left, the previous symptoms still occur. can ride it for now but will fix soon.
CNote
CNote
DirtyHustle
03-23-2014 02:34 PM
Jutboy
03-26-2006 03:13 AM
