changed rear turn signals and stuck
Hey, this is my first post on here so i want to say Hello to everyone on here. Earlier this week i bought some sweet new aftermarket tail lights for my 2007 Vulcan 500 LTD and i did changed the rear turn signals without a hitch and now, i have to front or rear turn signals. i mean, they're there haha but they wont work for nothin! and you can imagine how irritating it is. i checked all the fuses and they're all fine and also, i re-checked the wires i originally disconnected and notice that i had re-connected them probably. Any help? thanks in advance....
RE: changed rear turn signals and stuck
Are they LEDs? You might not have enough resistence in the bulbs to run properly (though I believe the usual symptom is a steady light, not no light).
Otherwise, break out a multimeter and start checking connections. Maybe you have a break in the line somewhere.
I don't normally like pipping other forums, but check out this one:
http://www.kawasakimotorcycle.org/forum/index.php
You'll most likely get a faster answer.
Also, there's an edit button. No need to make two posts.
EDIT:
What signals did you put on there?
EDIT:
joelcool64
09-28-2011 03:09 PM
LordVngr
10-30-2006 07:30 PM
