whining noise after letting off throttle
Old 06-02-2011 | 03:09 AM
Originally Posted by erictomlin
pbrider...it turned out to be a failing bevel gear bearing. Replacing the bearing was an all day job. I had to remove the bevel gear case from the engine. The manual will tell you that you need to remove the engine, but you don't have to. You will, however, need to lift the back end of the engine up until the top hits the frame. Then you will have just barely enough room to get the bevel gear case out past the frame.
I used a "running journal" from another poster (on another site) as my instrucion guide. It was most helpful. Here is the link.
Vulcan/Mean Streak Bevel Gear Assembly
Check it out and let me know if you have any questions.
Thanks for the assistance on this issue and congrats on the fix.
Old 06-17-2011 | 02:20 AM
pbrider's Avatar
Thanks Eric, mine also was my bevel gear bearing. It was completely destroyed. My mechanic friend did the work, and did not have to remove the engine either. The link was totally helpful, because the Kawasaki manual says the motor needs to be removed. So thanks to all who put in their two cents!
pbrider
AZR
05-10-2013 11:25 AM
pbrider
01-31-2012 03:30 AM
hoehoho
07-07-2009 03:50 AM
kawininja01
08-15-2008 09:48 PM
Bujin2000
09-09-2006 09:05 AM
