Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
Winterizing a STX-12F
Old Dec 7, 2006 | 07:39 PM
SCOOTER's Avatar
Default Winterizing a STX-12F
Besides stabilizing the fuel, changing oil & filter, fogging the engine & running Non-Toxic antifreeze thru the flushing port, what else should I be doing for winterizing?
I'm going to pull the battery & the ski will be stored in temps. down to zero F.
Old Dec 11, 2006 | 11:11 PM
meangreenman's Avatar
Default RE: Winterizing a STX-12F
> Get water out of the exhaust 4-1 collector pipe as much as possible to avoid cracking it when the staganant water freezes and expands. Run the engine and give a short quick high rpm blip.
> Remove spark plugs and spray some anti-rust spray (fogging oil, WD-40, etc.) into the holes to prevent rusting inside the cobustion chamber.
> Run fan inside the engine compartment to get rid of any kind of moisture currently there now. Then, place a 4x2 under the seat so that it can ventilate and evaporate any kind of moisture build up in the future.
> Hook up your battery to a automatic trickle charger. I'd rather place the battery in the boat and just run the engine once or every other week for a minute or so.
woodsman88
Jun 17, 2007 10:48 PM
mrjack
Feb 14, 2007 06:20 PM
jprickett
Oct 26, 2006 08:20 PM
b7202
Oct 24, 2006 08:29 PM
txparrothead
Sep 20, 2006 11:37 PM
