electric start in gear
Old Jul 25, 2010 | 02:23 AM
laytonc85's Avatar
Default electric start in gear
need help
2004 klx 250 have to start in neutral giving me the ****s. want to be able to start in gear with clutch in . can anyone help please ?
Old Jul 25, 2010 | 05:48 AM
MaverickAus's Avatar
disable the clutch cutout switch
Old Jul 25, 2010 | 12:17 PM
maninthesea's Avatar
I am guessing you may have broke the pin that comes out of the clutch swithc. Easy to do when you are changing out a clutch lever if your not looking out for it. Either way short term fix is disable the clutch switch. I forget if it is normaly open or normaly closed. first try disconnecting the plug. If that does not work then make a conection on across the two wires that go into the plug.
Cheers Jim
Old Jul 25, 2010 | 03:58 PM
GreenMonsta's Avatar
My clutch switch filled up with dirt and was giving me problems cleaned it and all is good.
Old Jul 25, 2010 | 05:49 PM
Check the clutch switch by the clutch lever.
Old Jul 26, 2010 | 08:23 AM
laytonc85's Avatar
thanks for all your help pulled the clutch switch apart, cleaned it out, put it back together ALL GOOD NOW
thanks guys
Old Jul 26, 2010 | 02:40 PM
Awesome...another happy ending........wait what?
Old Jul 26, 2010 | 02:55 PM
sw0ggd0gg's Avatar
Thats funny, mine sotck wouldnt start with out it bein in nuetral.
Old Jul 26, 2010 | 03:13 PM
ol'klx-er's Avatar
That would be the sidestand switch doing it's thing.
Old Jul 27, 2010 | 12:59 PM
sw0ggd0gg's Avatar
maybe, ill check it out again.
