klx300 running poorly
Old Jun 19, 2009 | 01:53 PM
rnacoyne's Avatar
Default klx300 running poorly
Hello,
I own a 98 KLX 300 that has developed a problem during my last ride. Anything over half throttle causes the bike to bog and back-fire and will produce some black smoke out the pipe. I was riding in an extremely wet and muddy environment. I have cleaned the filter element, cleaned the carb, replaced the plug and removed the cam cover to make sure the chain didn’t jump a tooth. All to no avail. Anyone have any suggestion as to what the problem might be? It has the Mukini carb with stroker pipe. Thank You.
Old Jun 19, 2009 | 02:48 PM
Well first of all, welcome to the forums. Second, when you say you cleaned the carb, what did you actually do? Did you pull the jets? Did you remove the float to make sure its not filling up with gas (pin hole?) Sounds like its getting too much gas. Keep us informed, and watch for more suggestions in here. Again welcome to the forums. Give us an intro on the new members page and become an active member. We could always use an extra crazy around here.
Old Jun 19, 2009 | 08:47 PM
your crazy enough for all of us deej!
Old Jun 19, 2009 | 09:11 PM
Hey as long as we are all in agreement.
Old Jun 21, 2009 | 12:50 AM
rnacoyne's Avatar
When I cleaned the Carb all as I did was brush the inside with some solvent followed by compressed air in the orifices.
I still have the stock CV carb so I put that one on and the bike ran as it should. Since I knew that I definitely had a Carb problem I cleaned the pumper more thoroughly by removing the pilot and main jets and the needle valve, spraying some carb cleaner in there and then compressed air. Put the pumper back on the bike and it runs as it should. I guess looks are deceiving I thought the carb looked pretty clean. Oh well lesson learned. I am using an inline filter and I have one of those K&N elements. But obviously something got in there. Thanks for the reply. I appreciate it.
dezzypoole
Sep 29, 2011 06:24 AM
Even Serpents Shine
May 23, 2011 01:46 AM
simes
Mar 9, 2009 09:38 PM
bailor
Oct 5, 2008 06:29 AM
WestOzKLX
Sep 8, 2008 02:14 PM
