brake fluid?
Old Mar 13, 2007 | 07:19 AM
vuskavich's Avatar
Default brake fluid?
I know im supose to use DOT4 but is there a specific brake fluid for bikes or can you just use anything???
Old Mar 13, 2007 | 08:02 AM
Default RE: brake fluid?
I am using the Motul RBF 600, it is rated pretty good and has a higher boiling point than some of the others.
Old Apr 24, 2007 | 11:08 AM
BVOYTEKB's Avatar
anything but synthetic.
Old Apr 26, 2007 | 02:53 AM
speedracer138's Avatar
I will use Motul Synthetic when I change my brake lines to steel braided. If you change to a different DOT # fluid, make sure to completely drain &flush the whole system. Some are not compatible with othersand can crystalize causing brake lock-up. When you flush it, use brake cleaner. Also use a new sealed bottle of fluid & be sure to bleed it really good before and after the test ride.
progrmr
Ninja ZX-7R
Jul 17, 2007 12:36 PM
PayneC
Mar 2, 2007 04:25 AM
ntloser
Oct 23, 2006 02:07 PM
buchut
Ninja 500R
Aug 7, 2006 10:17 PM
Icantrideabike
Aug 2, 2006 12:17 AM
